Sick 6cyl Bedford 330 Marine Diesel
Old Marine Engine » Diesel Inboards » Sick 6cyl Bedford 330 Marine Diesel « Previous Next »
phil_o
Username: phil_o
Posted on Monday, October 04, 2010 - 03:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi, I have a Bedford 330 in my boat whish which seems to have excessive pleasure in the block it is blowing what I believe to be atomised oil from the breather pipe and the rocker cover.
Can anybody give me any clues as to the cause of this any help it would be extremely appreciated.
Regards
Phil.
larry_from_md
Username: larry_from_md
Post Number: 24
Posted on Monday, October 04, 2010 - 08:44 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The most common cause is diesel fuel getting into the oil.This causes diluted oil and a high oil leval.The crankshaft spinning then wips it out anyplace it can.Causes are fuel pump diaphram,injestor pump seal leak,injector leaking or a cylinder not fireing.
phil_o
Username: phil_o
Posted on Monday, October 04, 2010 - 06:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Larry I will look into these hopefully it will solve my problem
