Standard engine
Old Marine Engine » One and Two Cylinder Gas Inboards » Standard engine « Previous Next »
jed_clamp
Username: jed_clamp
Posted on Monday, September 27, 2010 - 02:36 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Found this engine does anyone have any info on it? http://www.smokstak.com/forum/showthread.php?t=80503 Im having a hard time posting pics on this site...
rowella
Username: rowella
Post Number: 20
Posted on Monday, September 27, 2010 - 02:48 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does not look like any Frisco Standard engine to me.
jed_clamp
Username: jed_clamp
Posted on Monday, September 27, 2010 - 10:40 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I picked up a copy of Stan Grayson's American Marine Engines,and there is a picture on page 187 of a four cylinder 1908 Standard motor co. of New Jersey, that looks like the same engine. I think what confused me is if you look up Standard on the the home page of this website, there is a picture of this engine mixed with the Frisco's. I would like so see it run again. Any picks of the mag, or carb would be a help, as they are missing.
Post Number: 2455
Posted on Monday, September 27, 2010 - 04:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jed, That's a special Old Marine Engine !
Few marine engines this old had mechanical governors !
1909
s1
s2
s3
s4
s5
s6
s7
jed_clamp
Username: jed_clamp
Posted on Monday, September 27, 2010 - 10:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Wow! thank you so much for the info. Sounds like Standard made there own mag and carb? I would be stoked to find the correct parts, but I think that's a dream. Has anyone even seen one like this? I have yet to find any cbws. I think it may have been used in fresh water. One thing odd is it has a mag mount, and a dodge bros distributor that fits,and seems to be original. It also has two spark plugs per cylinder. I wonder if had a duel independent ignition system?
Post Number: 2456
Posted on Tuesday, September 28, 2010 - 12:28 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jed, Possible to Email me a set of good photos ?
I'll post them here>
[email protected]
jed_clamp
Username: jed_clamp
Posted on Thursday, September 30, 2010 - 12:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It will be a few weeks before I get back out to it. Thank you.
