Larry Evans
| Posted on Wednesday, September 25, 2002 - 11:50 pm: |
Is there anyone out there that is familiar with a 6 cylinder flathead Kermath marine engine, Model 100, Serial number 19930? Would like to know the bore, stroke, displacement, and year made. Also what type, amount, and brand of engine oil is used? Motor not seized, mag still works, distributor a bit tight. Has a brass Schebler carb and is opposite rotation engine.Primary question is the amount of oil required. Do you fill the small tank on the front of the engine or there some other level you go by? Appreciate any info you can pass on. Thanks in advance, Larry Evans. |
