Still need infor on Four-85
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Still need infor on Four-85 « Previous Next »
mike mcintyre
Username: tyeechaser
Posted on Thursday, August 26, 2010 - 07:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Model: Four-85.
Engine # K3239 with individual porting
Can anybody give me a year for this engine? And desirable compression reaadings? I got the manuals today and nothing in them re model # or compression. Somebody out there has to know! Thanks, MIketranny plate
kim hartshorn
Username: kimhartshorn
Posted on Thursday, August 26, 2010 - 08:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mike,
I got this url from an earlier post on this site
http://www.finewoodboats.com/Gray.htm
You will see that K numbers were 1958. However I have a motor with an engine tag on the Manifold identifying it as a model 620 and a tag on the transmission identifying it as a 4-75. I am wondering if this was common or if one or the other was replaced...and which one is original. Or if perhaps only the manifold was replaced.
mike mcintyre
Post Number: 7
Posted on Friday, August 27, 2010 - 01:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Kim,
Your post was most helpful. Thank a bunch! Got the exhaust manifold, carb, and oil color off and ready to lift the engine from the boat. Looks like all is well inside. Keeping my fingers crossed. The manuals arrived today and I read how water gets into these engines. Looks like that's what happened. Siphoned in from the watr intake.
M
