Priming pump
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Priming pump « Previous Next »
james nagel
Username: spindrift
Posted on Friday, July 30, 2010 - 08:07 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Has any found it necessary to grease or put soap in the water pump to help it prime? jim
Post Number: 1245
Posted on Friday, July 30, 2010 - 07:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
A worn gear pump yes
