Early 3 cylinder. Unknown manufacturer
Old Marine Engine » Unknown Engines - post here with photos » Early 3 cylinder. Unknown manufacturer « Previous Next »
chris berro
Username: helamog
Posted on Tuesday, June 29, 2010 - 03:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Inherited this with some antique car and truck stuff, and would like to find out more about it. Like does it look complete, and who was it manufactured by? Any help is greatly appreciated. Here is a link to my photobucket with all the pictures I have. If you need a more specific shot just ask.
http://s879.photobucket.com/albums/ab352/hellamog643/Early%20boat%20engine/
Post Number: 1219
Posted on Tuesday, June 29, 2010 - 04:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks like a Rochester from Rochester New York
Use the search function at the top and search for Rochester there are quite a few pics
Hope this helps
John Davis
Username: johnny
Post Number: 316
Posted on Wednesday, June 30, 2010 - 06:19 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
That piston stuck in the cylinder upside down through me for a loop there for about a minute. I finally landed back on the ground and think I got her figured out now. I do not know who manufactured the engine. Sorry.
Post Number: 1222
Posted on Wednesday, June 30, 2010 - 08:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here are the pics resized and brightened up.
Post Number: 1223
Posted on Wednesday, June 30, 2010 - 09:18 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here are pics of a 4 cylinder
http://www.oldmarineengine.com/discus/messages/2/131594.html
John Davis
Username: johnny
Post Number: 317
Posted on Wednesday, June 30, 2010 - 10:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Neat old engine! Are you going to get it running?
John Davis
Username: johnny
Post Number: 318
Posted on Wednesday, June 30, 2010 - 11:26 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Are the other two connecting rods on the pistons inside the cylinders? If not then your missing two con-rods and carb. Looks like the water manifold is built into the exhaust manifold. Correct me if I'm wrong but it appears that the exhaust manifold and the intake manifold are on the same side of the cylinder. Probably need a few buzz coils for the ignition. You may be missing some parts for your clutch. I do not see the clutch lever and mechanism.
chris berro
Username: helamog
Posted on Wednesday, June 30, 2010 - 12:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks for the help with the pictures Ernie. I'm not sure I'll ever get around to this project. I have not pulled them out, but I believe that the rods ore on the pistons, and it was put like this for shipping.
chris berro
Username: helamog
Posted on Wednesday, June 30, 2010 - 03:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think I have another box of parts some where with that handle and maybe some other bits. I'll have to dig around and get back to you.
chris berro
Username: helamog
Posted on Thursday, July 01, 2010 - 12:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I found some more parts. I have the flywheel and a long handle and mounting bracket. I have put the pics in my photobucket at the original link. I also laid out the parts that where in the small box. I did not find a carb though.
Post Number: 1224
Posted on Thursday, July 01, 2010 - 08:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here are the additional pics from Chris. The handle is for the reverse gear.
chris berro
Username: helamog
Posted on Thursday, July 01, 2010 - 03:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks again Ernie.
Ignazio Trovato
Username: ignazio_luciano
Posted on Thursday, July 01, 2010 - 10:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
engine
Hello
I have a marine engine 6354, 6 cylinders, aspirated, the serial number is not clear. I don“t know if you can help me, but I need to know where to find it? It was rebuilt in Turkey, in the 80's, but the builder is not able to help me with the number and I need it to obtain the EU certificate. Please help!!
