Albin 022 slipping
Old Marine Engine » One and Two Cylinder Gas Inboards » Albin 022 slipping « Previous Next »
buzzlovelace
Username: buzzlovelace
Posted on Saturday, March 06, 2010 - 04:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello,I hope you may have some insight to my problem. When I bring up the RPM's the motor slips until I bring them down an then slowly back up. Stephan suggested changing to Kendal Super D3, and I did do that but it still is slipping. As long as the RPM,s are low the engine runs fine. It has had this symptom for the year I have owned it. Is it possible that its a prop problem
Thank You
Albin 022 slippingMy Albin 022
nrorke
Username: nrorke
Posted on Saturday, May 15, 2010 - 09:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi,
I have an Albin 011 in my boat and it's run very happily for years. There is an adjustment that can easily be made inside the gearbox to avoid slipping -presuming that you have the same gearbox that I have, and that you still have the problem that is.
If you need a copy of the page in my handbook, email me for it. Best regards, Nick.
