Voltage of the cylinder head of Volvo...
Old Marine Engine » Multi Cylinder Gas Inboards » Voltage of the cylinder head of Volvo Penta 140 A gasoline engine « Previous Next »
mamij
Username: mamij
Posted on Tuesday, May 11, 2010 - 02:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi,
as the title says so, I need exact figures on how much cylinder head must be strapped to an old marine gasoline engine,
Thank you
fastimes
Username: fastimes
Posted on Tuesday, May 11, 2010 - 03:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am assuming that you are talking about the cylinder head bolt torque?
overhead cam 140 volvo the specs i have are:
1st stage torque 44 ft lbs
2nd stage torque 66 ft lbs
mamij
Username: mamij
Posted on Tuesday, May 11, 2010 - 03:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
yes sorry you are right, so are those the exact torque for the head for 140 A gasoline 4 cylinder marine engine?
fastimes
Username: fastimes
Posted on Tuesday, May 11, 2010 - 05:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yes right out of the book for a 140 hp overhead cam Volvo marine engine..starting from the center bolts working in an X pattern
