Zenith Carb High Speed Adjustment
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Zenith Carb High Speed Adjustment « Previous Next »
Ron Steiner
Posted on Monday, July 26, 2010 - 01:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What is the number of turns the high speed adjustment needs to be turned out after being turned all the way in to a dead stop?
I just seem to be having a problem on any single adjustment.
What is the proper method in which to reach the optimum setting?
Pete Oquist
Username: 63woodpony
Posted on Tuesday, July 27, 2010 - 04:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ron, it depends on the model but I just adjusted my Zenith updraft carbs Sunday. My manual says two full turns out after it is turned all the way in. The idle adjustment is 1/2 turn. Hope this helps
