Gray Model 70 advice
Old Marine Engine » Multi Cylinder Gas Inboards » Gray Model 70 advice « Previous Next »
Pete McDonald
Posted on Sunday, September 22, 2013 - 10:11 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Gray Model 70 that will not accelerate under load. Starts and idles fine and will rev up to 4000RPM in neutral but in gear it will not rev higher than 2000RPM. It needs a general tune up, but it feels like something else is wrong here. Appreciate any advice.
Post Number: 721
Posted on Sunday, September 22, 2013 - 12:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It sounds as if the carb is set too lean - or there is a schmutz clogging the jet.
If your engine has not been serviced for some time, make sure you do a really thorough carb cleaning.
