gene1605
New member Username: gene1605
Post Number: 1 Registered: 04-2010
| Posted on Saturday, April 17, 2010 - 03:18 am: |
I just became the new owner of a 1980 23 ft vashon pocket trowler with 66 hrs. total time. It has a sabb 2gz 22 hp. engine and a sabb reverseible prop. The engine started and ran. The fuel filter has no numbers on it and the paint has peeled off the oil filter the partshouse books noes not show this boat or motor, I would greatly appreciate any help that I can get get. the filter numbers the sabb gives does not show in the fram crosover book. Grampa} |
larry_from_maryland
Post Number: 395 Registered: 07-2003
| Posted on Saturday, April 17, 2010 - 11:06 pm: |
Go to the Napa filters site and type in the numbers in their search area.I can look in the big napa book tomarrow. |
gene1605
Post Number: 2 Registered: 04-2010
| Posted on Sunday, April 18, 2010 - 11:25 pm: |
Larry could you look in the big book for me, I haven't had any luck with the coumpter. I started and ran the 2gz engine today for about 10 min. today, started and ran well, after sitting for 20 + yrs. I should change filters thanks, Grampa |
larry_from_maryland
Post Number: 398 Registered: 07-2003
| Posted on Monday, April 19, 2010 - 06:59 pm: |
There is no listing for Sabb in my book. Do you have any numbers sabb or anything. |
gene1605
Post Number: 3 Registered: 04-2010
| Posted on Tuesday, April 20, 2010 - 03:28 am: |
Larry today I went to a old local auto parts store, they knew exactly what oil filter I wanted but was a loss on the fuel filter, there is no numbers on it, I will take it and have it measured tomorrow I'm sure they will find something. Larry I appreciate you trying to help if you ever get up here to anchorage I will buy lunch. Grampa |
jimdereynier
Member Username: jimdereynier
Post Number: 27 Registered: 08-2007
| Posted on Tuesday, April 20, 2010 - 04:26 pm: |
Sabb Fuel filter: You are better off using an old fashion glass bowl fuel screen for 100 micron followed by a Parker Hannifin ( or whatever) 10 micron filter assembly you find in any marine shop.- Both of them allow you to see what crud was pumped into your tank. ( Down stream of this I have the standard Sabb fuel filter that I have not changed in 8 years- probably filters at no finer than 50 microns) |
gene1605
Member Username: gene1605
Post Number: 4 Registered: 04-2010
| Posted on Wednesday, April 21, 2010 - 01:28 am: |
Jim, good idea I have a rakcor that has a clear bowl with a drain and will be easy to mount. Grampa |
