Chinook sliding gear box
Old Marine Engine » Gears, Transmissions, and Propellers » Chinook sliding gear box « Previous Next »
Kleaman
Username: bailey
Posted on Sunday, April 26, 2009 - 07:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 16' (old) clinker with a Briggs & Stratton inboard connected thru to a gear box with foward, neutral and reverse. It is a sliding type gear box. It has Chinook and Seattle cast in the housing of the unit. Have not tried it out in the water yet and wanted to know more about the gear if anyone had any info on these units. Seems like a good system, heavy built cast iron case that splits for servicing.
Any info would be appreciated.
Regards
Paul Huffman
Username: boatpaul
Posted on Monday, June 15, 2009 - 08:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I dont know if this will help,but get ahold of the Center for Wooden Boats in Seattle and talk to the director,he is very familiar with Ronald Young's poulsbo boats which may have had that gear as an option.The boat you have was very common on Vancouver Island,wish I could find one now!When I'm up there,I'm usually between Parker Is.& Ganges,just dont see them around anymore.Paul
Paul Huffman
Username: boatpaul
Post Number: 15
Posted on Wednesday, April 20, 2011 - 01:03 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Did you ever get any info on that gear? Machine shop repair/refurbish Call me @360-301-2084
