One cylinder dunn?
Old Marine Engine » Dunn » One cylinder dunn? « Previous Next »
stephen craig
Username: bristol20
Post Number: 19
Posted on Friday, July 13, 2012 - 07:13 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hello there,
collected this little engine the other day, looks like a dunn , was woundering if enyone can confirm this.
Would love some feedback! can someone put a date to this little engine ? im in Australia thanks
Steve Craig.
Post Number: 1532
Posted on Friday, July 13, 2012 - 12:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yes it is a Dunn
Your engine looks like the Blue one in this post.
http://www.oldmarineengine.com/discus/messages/1/254831.html
Lots of Dunn info here. Just use the search function at the top
Hope this helps
stephen craig
Username: bristol20
Post Number: 20
Posted on Tuesday, July 17, 2012 - 10:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Ernie
looks like a few parts missing regarding ignition. on the blue engine, there is a handle with what looks like a copper strip, i guess this is the timmer. can you thell what material that bushing that the copper strip wipes on be made off and would that bush be earthed to the engine. also in your opinion do you think the flywheel is original it has a diffeerent hole pattern again.
thanks Steve.
Post Number: 1536
Posted on Wednesday, July 18, 2012 - 07:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Steve,
Not my engine
Hopefully Jeff K will join in
Doug Kimball
Username: doug11k
Post Number: 82
Posted on Wednesday, July 18, 2012 - 07:47 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have two small Dunn singles ... an early and a late. Early has no holes in flywheel & late has four. The late one is a little thicker than the other but does not look as thick as your 3-holer. The timer insulating bushing is made of a red material that I've seen on other engines also but I don't know what it is. There are suitable modern, machineable, high dielectric material but I've not seen the same dull, brick red color.
Dunn timer
Jeff Kitzmiller
Username: jeffk
Post Number: 9
Posted on Wednesday, July 18, 2012 - 11:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Steve,
As far as I can tell the blue engine's ign is complete. Just needs some TLC.
Jeff
