Graymarine 4-45 ???
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Graymarine 4-45 ??? « Previous Next »
Mike Mosier
Username: hoss109
Posted on Sunday, March 04, 2007 - 01:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm looking at a 1949 Lyman with a Gray 4-45. Can anyone tell me what model that is? Sea Scout, Phantom etc; I'm trying to determine if it could be original/correct for the boat. Thanks!
Bruce Hall
Username: bruce
Post Number: 135
Posted on Sunday, March 04, 2007 - 03:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mike, can you provide the Gray serial number? Have you contacted the Lyman society yet? The Phantom 4-45 appears in My 1950 Gray owners manual.
Mike Mosier
Username: hoss109
Posted on Sunday, March 04, 2007 - 04:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I asked the question on the Lyman forum too Bruce. No response yet though. I'll try and get the ser# on my next trip to boat.The boat ser# indicates it was one of the last 4 built in 1949 so a 1950 engine would be entirely possible. Thanks!!
Arnie Burnham
Posted on Monday, March 05, 2007 - 04:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mike, I have a 1950 Islander that I'm restoring. It has a Lugger Sea Scout 25hp in it, but I recently purchased a Phantom Four-45 for it. It is the same block as the Sea Scout (91 cu in) and it even has the same motor mounts. I think the Islander may have come with the 45 as an option. It will be in mine. I've heard the 25hp engine is not quite enough. Post your question to Tom Koroknay at www.lymanboats.com on the question and answer page. He has all the hull cards, so be sure to add your hull number. My Islander is A-1622, just a little newer than yours. Hopefully the boat your looking at is in good shape. Arnie
Mike Mosier
Username: hoss109
Posted on Monday, March 05, 2007 - 07:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Arnie! It's looking like that's the right engine. I'll post to TK, I
have his book. The ser# ( A1428 ) says it's one of the last 3 or 4 built in
49'. Someone else responded that they had an early 50' with a Four-45 so it
makes sense. I'll post to Tom and verify hopefully.
The boat needs decks and shear planks but it can be saved. Thank's, Mike
Peter Anderson
Username: 57centuryviking
Posted on Wednesday, March 28, 2007 - 01:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am also in need of some info for rebuilding purposes. I have a 57 Century Viking with a 4-45 Gray Mairine engine in it. Where on the engine can I find an ID # to identify if it's a Continental or Gray Marine? The manual I obtained is for a different engine, which states the serial # is on the transmission plate. It is not. Any help would be greatly appreciated. Thanks, Pete
Mike Mosier
Username: hoss109
Posted on Wednesday, March 28, 2007 - 01:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Afraid I'm not much help Pete.I haven't got the boat yet.I only know the Model because I saw it on the exhaust manifold.Don't know where the ser# is. Good Luck. MM
JOHN DEBATES
Username: cam_gear
Post Number: 11
Posted on Wednesday, March 28, 2007 - 04:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
HI PETER
YOUR ENGINE IS A CONTINENTAL BY GRAY MARINE.
THE SERIAL # WAS PUT ON THE TRANS PLATE.
YOU CAN TRY THE GUYS AT GRAY MARINE, INC.
630-485-5007 THE MORE INFO.
JOHN
Peter Anderson
Posted on Thursday, March 29, 2007 - 08:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mike & John, Thanks for the quick response. The data on the transmission plate is such, Gray Marine, 4-45, Eng No M2230. Is this M2230 the serial # or another type of identification #? If this is not the correct number, is there another place on the motor where I can find this identifying number? Thanks, Pete
Mike Mosier
Username: hoss109
Posted on Thursday, March 29, 2007 - 09:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'd say that's it Pete. Engine No is usually the same as Serial No. Have fun!! MM
JOHN DEBATES
Username: cam_gear
Post Number: 12
Posted on Thursday, March 29, 2007 - 11:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
HI PETE
ENGINE #M2230 WAS BUILT IN 1959 LOT M2200-M2299
AS A 4-45.
JOHN
david h. hughes
Username: hughes
Posted on Monday, November 23, 2009 - 04:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i have gary phantom4-45 sereal#d 22128 does anyone know what year it is and are parts avail dave hughes
john st clair
Username: salmonator
Posted on Saturday, January 16, 2010 - 04:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just got a 4cyl gray marine four-45 eng no D-1517 any way to find out when it was made?
Mike Mosier
Username: hoss109
Post Number: 10
Posted on Sunday, January 17, 2010 - 05:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I did buy that boat. I'll try and upload a few before and after pics. Mike1949 Phantom Four-45
