Flywheel for 1911 Gray Single
Old Marine Engine » Gray Motor Co - early 1 and 2 cylinder » Flywheel for 1911 Gray Single « Previous Next »
Post Number: 2241
Posted on Tuesday, November 17, 2009 - 11:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Need a Flywheel for this 1911, 10 Hp Gray single.
Gtag2
Gsingle3
The shaft is straight and outside diameter is 1 13/16 inches.
Previous owner removed the original because it was to small to run the engine on a stand, it's a real thumper !
Used another flywheel to run the engine that was 18 inches diameter and 130 lbs. A bit bigger would be OK.
Any help appreciated !
