Can anyone tell me what this engine is
Old Marine Engine » Diesel Inboards » Can anyone tell me what this engine is « Previous Next »
wordave
Username: wordave
Posted on Saturday, September 13, 2008 - 07:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
how old what size, any info at all cant seem to find anything like it , loads of coventry engines but none like mine,most grateful for your help
engine number is c d m o /383/252, it came out of a fire damaged barge, cheers, wordave
listerdiesel
Username: listerdiesel
Post Number: 24
Posted on Tuesday, October 07, 2008 - 04:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Coventry Climax did a CDM engine, I'll check my catalogues tonight and see how theyb compare.
If you could get the full number off the injection pump, that would help also.
Peter
wordave
Username: wordave
Posted on Tuesday, October 07, 2008 - 04:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
pump has numbers on it , 351/1
2000
a,v,r6967bx
a 60s200563
L 20 [ ]cant make out this letter or number 43
variable
30138
wordave
Username: wordave
Posted on Tuesday, October 07, 2008 - 05:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Post Number: 872
Posted on Tuesday, October 07, 2008 - 08:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The reverse gear and bellhousing adaptor sure look Yanmar. However the flywheel housing is most likely a standard size.
You can check the numbers on the reverse gear and they may help you identify it and possibly the engine
martin ellis
Posted on Monday, November 02, 2009 - 03:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Your engine is:- a COVENTRY DIESEL C.D.M.Q 383 (note Q not O) normally fitted into fork trucks and the likes, could be 15hp could be 18hp not sure which yours is, and I do not know how to date it, wish I did, as I have one myself, rathe envious of the gearbox on yours, mine has a simply clutch housing and output flange, best regards martin
