GMC 4 Cyl 3.0L inboard
Old Marine Engine » Boats with Early Inboards » GMC 4 Cyl 3.0L inboard « Previous Next »
ronniemon
Username: ronniemon
Posted on Friday, November 06, 2009 - 01:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Having trouble with water in the oil. Put new head on. Do I assume it's a bad block and if so what next?
Post Number: 409
Posted on Friday, November 06, 2009 - 09:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sounds as if the water jacket has rusted out .
The only realistic repair is a wet sleeve, I think.
But if you are lucky, and the location is not under compression , JB Weld might do the trick.
That means total disassembly.
