Don Reid
New member Username: dishwasher
Post Number: 1 Registered: 11-2009
| Posted on Monday, November 09, 2009 - 08:46 pm: |
New here looking for information on a JXDM engine # 1760132. I have been told that the 'M' stands for marine. but engine was out of a loader. My problem is in order to run engine it needs a distributor cap but caps aren't tall enough that the parts supplier says should fit. Delco Remy Distributor number is 1111807- 6A16 Points line up with cam on shaft but rotor sits too high for caps numbers RR142 ,RR95 Any information might help The Dishwasher |
Lawrence T Wolfe
Post Number: 383 Registered: 07-2003
| Posted on Monday, November 09, 2009 - 10:13 pm: |
Well do you have the piece that goes between the cap and distributor. There is a part that divides the point area from the high voltage upper part. This part gets misplaced and there is NO way to fit a cap on there with out it.Its sort of a disc with a hole for the roter in it. Don't ask how i know this. |
Scott Noseworthy
Post Number: 123 Registered: 02-2008
| Posted on Tuesday, November 10, 2009 - 08:14 am: |
you can get tune up parts at NAPA still |
Don Reid
Post Number: 2 Registered: 11-2009
| Posted on Thursday, November 12, 2009 - 08:36 pm: |
Larry found the disc in the bucket after figuring out from your message and looking on google images. surprising the help that is out there when you know where to look . thanks for the help . Scott have located the points rotor etc at napa. Will wait to see condition of engine once it fires up. Don The Dishwasher & Vintage DT |
