Model 32A
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Model 32A « Previous Next »
Jim T
Username: brownboat
Posted on Thursday, June 07, 2007 - 08:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I recently acquired a Model 32A #2077
I haven't been able to find much info on the model or where I might find some parts or a parts book. Can anyone provide any information??
Roger DiRuscio
Username: solarrog
Post Number: 250
Posted on Thursday, June 07, 2007 - 08:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can you help us with a brand name??
HP
age???
Picture??
Lawrence T Wolfe
Username: larry_from_maryland
Post Number: 247
Posted on Thursday, June 07, 2007 - 09:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I don't see a 32 under grey. 32a was an old chrysler flathead number.
Jim T
Username: brownboat
Posted on Thursday, June 07, 2007 - 09:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The plate on the transmission is a "Gray" shield type. I can get more info off the block in a day or so as well as a photo. I found a reference to a Gray Model 32 Phantom in the carberatorshop carb x-reference table
Bruce Hall
Username: bruce
Post Number: 146
Posted on Friday, June 08, 2007 - 08:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Gray model 32 phantom was the factory specified engine in the first series Penn Yan Imperial inboard runabouts from the early nineteen thirties. The Fingerlakes boating museum is restoring an early Imperial(V-drive configuration) and would like very much to learn more about this engine Jim T. See www.FLBM.org for details on this restoration effort.
Brownboat
Username: brownboat
Post Number: 10
Posted on Thursday, November 05, 2009 - 10:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
the Gray Model 32A is a small four cylinder engine with transmission. i don't have any of the V-drive parts. It is about the size of a Kermath Sea Cub or Buchanan Midget. Before winter I will get a few pictures of it to post.
