Two Sparks "instead of one"
Old Marine Engine » One and Two Cylinder Gas Inboards » Two Sparks "instead of one" « Previous Next »
Post Number: 2230
Posted on Friday, October 23, 2009 - 02:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
"Double the fun" Two Sparks "instead of one" 1919
tt19
Post Number: 1086
Posted on Friday, October 23, 2009 - 02:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Another good idea that wasn't
I suspect that they found out rather quickly that if half of it was fouled the other half was too.
amanco
Username: amanco
Post Number: 9
Posted on Monday, October 26, 2009 - 02:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Actually the idea was for costly battery savings. You would start the engine on the battery powered high tension buzz coil and then switch over to the magnet powered high tension magneto. Maybe couldn't start on mag because of the slow engine speed when turning by hand. Of course this was overcome on tractors by adding an "impulse" which allows the mag to, in an instant, act quickly at the right time thus delivering a hot spark.
VERY cool advert! Thanks for posting!
