Kennebec Ignition
Old Marine Engine » Multi Cylinder Gas Inboards » Kennebec Ignition « Previous Next »
Post Number: 2186
Posted on Tuesday, September 22, 2009 - 10:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
1908 Kennebec shows a gear driven drum operated
magneto, anyone have an engine or photos one of these ignition systems ?
k1
k1a
k1b
Post Number: 2187
Posted on Tuesday, September 22, 2009 - 10:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
After searching old posts here I found these catalog photos and Its not a magneto but a lever operated timer !
ko1
ko1a
ko1b
Post Number: 1048
Posted on Tuesday, September 22, 2009 - 03:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Rochester was very similar. I have pics somewhere....
searcher
Username: searcher
Post Number: 366
Posted on Monday, November 02, 2009 - 12:37 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
For awhile I thought these timers were made by Torrey Roller Bushing for their own engines. However, I have since seen other engines in ads that used these identical timers. Apparently, there was a supplier out there somewhere who sold them off the shelf. This timer is missing it's handle and knob, a loss I hope to remedy when I attempt to learn how to use a lathe this winter. I have the two cylinders (cracked from salt damage), the flywheel with half the crankshaft, the base, the timer, and one piston for this engine. Maybe I'll get lucky and find another one with the needed parts. Right!!!!!
