Volvo penta 170 overheating
Old Marine Engine » Miscellaneous » Volvo penta 170 overheating « Previous Next »
blindsay
Username: blindsay
Posted on Tuesday, July 21, 2009 - 09:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
we changed a cam in the motor ran fine for breakin when boat idles it over heats raw pump is fine circ pump seems to work took thermostat out will cool @ high idle any ideas
boatpaul
Username: boatpaul
Post Number: 12
Posted on Friday, October 16, 2009 - 10:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
blindsay,check your exhaust manifold,especially the elbow that mix's the exhaust& water prior to going through the transom.If used in salt water it may be terminal.The cast iron literally swells the water passages shut.If this is the case,you might get lucky by rodding it out.Good luck
