P60 Idle
Old Marine Engine » Palmer Engine Co » P60 Idle « Previous Next »
tim walker
Username: i_fix_it
Posted on Monday, May 16, 2011 - 09:42 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My P60 will not idle down below 1000 RPM. I've done the normal , plugs points condesor rotor and cap , I rebuilt the carb and it looked brand new inside. After all this it ran perfect for about two hours and then the idle speed started climbing. When I turn down the stop scew it stalls, The idle mix screw makes a diffrence but does not cure the problem. THank, Tim
Post Number: 593
Posted on Monday, May 16, 2011 - 08:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sound like a vacuum leak. At the shop we have a smoke generator to check for leaks, if you don't have any luck you may find a nearby shop with one.
