jimsnap
New member Username: jimsnap
Post Number: 2 Registered: 07-2009
| Posted on Thursday, July 09, 2009 - 12:33 pm: |
hi can anyone help. my albin 0-21 had a slight overheat the other day ( forgot to turn on raw water feed for 2 mins) and since then has lost power under load, ticks over fine and compression seems ok. there is a slight spitting sound. it may be that the overheat had nothing to do with it so any help or explanation would be gratefully received. thanks |
maartenklop Visitor
| Posted on Monday, September 21, 2009 - 05:05 pm: |
loosing power under load means the ignition is not ok. Check sparkplugs, cabels, coil, condensator etc. |
john_archibald
Senior Member Username: john_archibald
Post Number: 116 Registered: 08-2006
| Posted on Monday, September 21, 2009 - 07:59 pm: |
Do you have the oil mixture right on this engine? If you don't have enough oil, it would stall after a little while of running just fine. I presume that it is a 2-stroke engine. Just lurking, haven't been following much. Archibald Northfield, Minnesota . |
