Bmc 1.5 diesel inboard
Old Marine Engine » Diesel Inboards » Bmc 1.5 diesel inboard « Previous Next »
vitty
Username: vitty
Posted on Thursday, June 25, 2009 - 03:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
got a bit of a problem or have i my bmc engine wont fire water out of exsaust till about 5 minutes till the thermostat opens is this ok or do i have a problem ive checked for blockages but cant find any help would be great the thermostat is a 82
boatpaul
Username: boatpaul
Posted on Friday, June 26, 2009 - 11:01 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
vitty,even with a raw water cooled engine,you should still have water going through the exhaust.Otherwise your going to burn a hole or otherwise compomise your exhaust system.See if you can find a schematic of your cooling system in your engine manufacturers manual.
Paul
