Krice Carb photos from Dick Day
Old Marine Engine » Carburetors, Mixers, Vaporizors » Krice Carb photos from Dick Day « Previous Next »
Moderator
Username: andrew
Post Number: 1162
Posted on Monday, June 27, 2005 - 06:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The following comments and Krice Carburetor photos came in from Dick Day:
quote:
There was a question raised the other day what the carburetor main body was from. Perhaps these photos will be of some use in the discussion. ... Regards, Dick
1
2
3
4
5
6
7
keith
Username: keith
Post Number: 193
Posted on Monday, June 27, 2005 - 07:41 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dick
I thought Ernie trained / instructed you on the art of posting pictures. Was he a bad instructor or were you a bad student?
Keith
richardday
Post Number: 419
Posted on Monday, June 27, 2005 - 08:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
He is a great instructor. My problem is I am computer illiterate. At least I was able to get the photos down to 400 pixels and under 50 Kbytes so I am now ready for the next level.
Moderator
Username: andrew
Post Number: 1163
Posted on Monday, June 27, 2005 - 09:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
One step at a time... you're making great progress on the computer Dick! .
The picture posting can be difficult.
richardday
Post Number: 420
Posted on Tuesday, June 28, 2005 - 11:26 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I don't understand why the photos lost their titles in the transfer to you. Any ideas anyone???
Post Number: 514
Posted on Tuesday, June 28, 2005 - 05:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dick,
Give me a call.
Frank Petran
Posted on Friday, May 08, 2009 - 02:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
By any chance is this carb for sale. Frank Petran [email protected] 262-284-3650
John Davis
Username: johnny
Post Number: 185
Posted on Friday, June 26, 2009 - 07:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Frank,
Did you notice the posting date of the Krice carb info? This was posted back three or four years ago. I guess there might be a chance that Dick still has the carb?
Frank Petran
Username: frank_petran
Post Number: 36
Posted on Friday, June 26, 2009 - 05:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dick,
Two things, first, in the picture of the Carb showing all the parts there is a ring or something resting on the inner body and the outer body gas level and assembly part. I don't have one on my carb. Second, Do you still have the carb and if so is it for sale? John, Thanks for the tip. Frank
Post Number: 981
Posted on Friday, June 26, 2009 - 06:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Frank,
I actually took those pics for Dick Day and I think you are talking about the float. If you are missing yours you can get one from Dave Reed at Otto Gas Engine works.
click here
Frank Petran
Post Number: 37
Posted on Friday, June 26, 2009 - 09:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ernie,
I bouoght a new float from Dave Reed. What I am refering to in the pictures there is some kind on washer/spacer resting on the top of that round piece that holds the two pieces, Upper and lower halfs together. It is the one with the nut on the bottom of the carb. In the picture there is some kind on washer/spacer resting on the top of that piece. I looked at the cross section of the Krice Carb that is under a different topic that I downloaded and I can't name that piece or find that washer/spacer on the drawing. It is the piece where the main or idle needle valve fits into for fuel control. As I haven't run my engine (flywheel is being cast next week and then machine shop) I don't know how much control the needle valve has over the fuel flow. On the first picture it is on the left side of the picture above the nut and the washer/spacer is resting on that main or idle jet, on the second picture washer/spacer is right of the nut below the main carb body and resting on the main or idle jet body. Could the round thing be the gasoline vaporizer? But I don't have that washer/spacer or any idea what it does or what it looks like.
Post Number: 982
Posted on Friday, June 26, 2009 - 09:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Frank,
I will have to take one apart and refresh my old brain. I took those pics a long time ago.
I will take a few more pics when I look at one. It won't be for a day or so
Post Number: 767
Posted on Sunday, June 28, 2009 - 04:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Unfortunately I am out of town for a couple of days. Will have a look at my stock of Krice Carbs and see what I have. Will get back later in the week.
