Palmer Engine Parts needed
Old Marine Engine » Palmer Engine Co » Palmer Engine Parts needed « Previous Next »
John Matter
Posted on Sunday, December 09, 2007 - 09:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I need a head gasket & standard piston rings for a Palmer PW27
Post Number: 545
Posted on Monday, December 10, 2007 - 08:34 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am working on getting a good used PW-27 head gasket for Gaskets To Go so John can make up compressible copper head gaskets. The piston rings are Wisconsin Piston model DB-210 rings. Don't talk Palmer talk Wisconsin when looking for rings. Hope this helps.
Post Number: 547
Posted on Tuesday, December 11, 2007 - 07:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Piston Rings for Wisconsin Piston DB-210, are Hastings, 4215. You can confirm this with Hastings.
John Matter
Posted on Wednesday, January 16, 2008 - 08:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard-- Thanks so much for your help.For your information, Molina Gasket Co. in Torrence Cal. Made me a perfect copper compressible gasket. Expensive but excellent quality. Thanks again John
John Matter
Posted on Thursday, June 04, 2009 - 05:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a small one cylinder KERMATH engine and am in need of a new magneto gear. Can you help? The number cast in the block is B17524. Also any info would be appreciated. Thanks, John
