Palmer NR 1
Old Marine Engine » Palmer Engine Co » Palmer NR 1 « Previous Next »
Bryon Bandemer
Username: wydiver
Post Number: 19
Posted on Thursday, June 14, 2012 - 05:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Helping out a friend, Where do you find the serial number on this engine? There is no Label plate. I am trying to get a date of build.
thanks for all the help
Bryon
Bryon Bandemer
Username: wydiver
Post Number: 20
Posted on Thursday, June 14, 2012 - 05:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Post Number: 1008
Posted on Friday, June 15, 2012 - 06:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does the flywheel have a gib key or the left hand Puller nut ?That change to left had puller nut took place 1922/23. Serial number brass tag in early years was mounted on forward face of cylinder. Later years next to the timer mounting. Water pump with built in check valves came on stream about 1919. Oil pump in early years was 1/8" pipe up through the crankcase. about 1920 changed to copper tubing to top of oiler site glass over intermediate gear.Very early oil pump was brass. Later units cast iron. NR was normally timed for left hand meaning counter clockwise facing the flywheel. Compression relief should be pulled forward as soon as engine starts. Left hand thread puller nut cap screws are probably 1/2" 12 thread. Some made post about 1930 are found with 1/2" 13 thread and a very few with 3/8" 16 Thread. All puller nuts are left hand thread and don't over tighten trying to line the cap screw holes with the puller nut. Some may but most won't and you can destroy the puller nut threads on the crankshaft trying to make them line up. Any Palmer cast iron castings with MFCO in a diamond were cast post 1937 By Manufactures Foundry, Waterbury, CT.
Bryon Bandemer
Username: wydiver
Post Number: 21
Posted on Sunday, June 17, 2012 - 01:55 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks for the reply Richard. It has jib key on the flywheel. I also has brass oil pump with 1/8" piping through the crankcase. I did not see any holes where a label was attached. I have to check the waterpump soon to see if it has check valves. So this thing runs to the left if your looking at the flywheel from the front?
This will take some work, but at least it all came apart without heat.
Thanks for all the help. I will have to find some manuals so I can get back together and timed correctly.
Bryon
Bryon Bandemer
Username: wydiver
Post Number: 22
Posted on Wednesday, October 03, 2012 - 03:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
here is the video of the restored engine. Thanks for all the help and information.
http://www.youtube.com/watch?v=3LxybSnfVKg&feature=g-upl
Post Number: 730
Posted on Wednesday, October 03, 2012 - 08:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks and runs great Bryon, can't wait to see it.
Bryon Bandemer
Username: wydiver
Post Number: 23
Posted on Thursday, October 04, 2012 - 07:20 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks J.B. I hope I am in for the get together in Patterson. I might just have to load up and head to Donaldsonville.
Post Number: 733
Posted on Thursday, October 04, 2012 - 10:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bryon brought the motor to the shop today, it fired right up and ran great, not a lot of Palmers in our area.
