RPMs
Old Marine Engine » Palmer Engine Co » RPMs « Previous Next »
Tom Kelly
Username: tom_k
Posted on Tuesday, May 26, 2009 - 03:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a palmer 60 in a 30 ft sailboat.Rcently I replaced the origornal prop with a indigo three blade prop.It was a 1 to 1 ratio before.Indigo says the cruesing rpms should go from 1600 to around 1900.The engine will not turn over 1700 and at that makes strange sounds.Ive been told valve float or preegnition.Any ideas.
Eddie Ross
Username: eddie
Post Number: 233
Posted on Tuesday, May 26, 2009 - 11:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The noise might be pinging (engine knock) which usually indicates that the ignition timing is too far advanced. Disregard valve float.
