Jim Parrott
Senior Member Username: jim_parrott
Post Number: 144 Registered: 06-2009
| Posted on Monday, August 28, 2017 - 03:53 pm: |
Any idea who made this 2 port engine?
Any help would be appreciated. Jim |
Jim Parrott
Post Number: 160 Registered: 06-2009
| Posted on Thursday, January 04, 2018 - 04:13 pm: |
Posted this one a while back, figured I would bring it up again. Any idea of the manufacturer? |
Robert
Post Number: 918 Registered: 07-2003
| Posted on Wednesday, January 10, 2018 - 12:22 pm: |
What's the petcock in the cover plate all about? |
Post Number: 1354 Registered: 07-2002
| Posted on Wednesday, January 10, 2018 - 07:00 pm: |
Just a guess but I would say an attempt a economy, I've seen several variations. An old fisherman told me you could open t to allow more air and save fuel. adjusting the carb would do the same thing. |
Jim Parrott
Post Number: 176 Registered: 06-2009
| Posted on Monday, February 26, 2018 - 10:22 pm: |
Cleaned up my little unknown engine today and noted that I had an oddball grease cup. Having a matching spare with 1/4� male threads instead of 1/8� female threads, I decided to try a conversion. First I cleaned it up, chucked the hex end in the lathe, cut the off center hole bigger with a end mill. Drilled to size and tapped 1/8� npt enough to hold it, then screwed in a 2� pipe. Rotated it in the chuck, faced it off and turned down the threads. Removed from chuck and retapped from outside end. Worked out pretty good and now have a matching set.
Robert
Post Number: 943 Registered: 07-2003
| Posted on Monday, February 26, 2018 - 11:01 pm: |
Clever! If you'd used a brass nipple no one would ever guess. |
Jim Parrott
Post Number: 178 Registered: 06-2009
| Posted on Tuesday, February 27, 2018 - 10:37 am: |
Robert, I prefer brass fittings, but the other cup has a steel nipple that looks original, so I wanted to match it also. Jim |
