captain_lyerly
New member Username: captain_lyerly
Post Number: 1 Registered: 03-2009
| Posted on Sunday, March 08, 2009 - 05:24 pm: |
What would be a practical size steam engine for a fantail launch, steel hull (1/2" plating) of around 50 feet length? Vessel currently has a Graymarine diesel, and eventually I would like to convert to steam - it was built in the early 20th century, and I am not sure that it wasn't originally steam-powered. There is clearance for an over-sized propeller, if that would help. Thank you for any assistance you may be able to render. Cap'n L |
boatbum
Member Username: boatbum
Post Number: 12 Registered: 05-2006
| Posted on Monday, March 09, 2009 - 04:14 am: |
There are a lot of factors in determining the correct size of engine for your vessel. What is the beam, draft, hull type, screw size, etc of your vessel. I have seen boats near your size with 75hp multi expansion engines and I have seen 30' with 12hp ones. How fast do you want to go and at what rpm? I have a 78' steel yacht built in 1929 powered by a Atlas Imperial diesel (her original power plant) that is 140-160 HP turning a 56" X 38" screw. At 300 rpm she goes 12 knots, cruise 9 knots. |
Senior Member Username: miro
Post Number: 359 Registered: 11-2001
| Posted on Monday, March 09, 2009 - 03:17 pm: |
If you'd like to do some research on the subject I would highly recommend 2 books. Weston Farmer's From My Old Boat Shop and The collected magazine reprinted from the early 1960's that was published quarterly for 3 years on the subject of smaller steam launches. I bought both of them through this web site. You frankly can't get much better than the info in those 2 references. As my better half describes it, I was like a teenage boy with his first porn magazine when they came in :-} miro |
