Help Needed - Two Cylinder Inboard ID
Old Marine Engine » Unknown Engines - post here with photos » Help Needed - Two Cylinder Inboard ID « Previous Next »
AJ
Posted on Saturday, February 21, 2009 - 09:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi All
This site was recomended as "The" place to have
the identity determined of an early 2 stroke inboard.
I have attached two photos of the subject.
It's not my engine, but that of a friend who has had
it wrapped up and tucked away in the corner of his
shop for many years. He has been bugging me with
"You can find it on the internet can't you?".
Hopefully he's right!!!
Thanks and regards
Art Engine Pic - 1Engine Pic - 2
Post Number: 933
Posted on Sunday, February 22, 2009 - 05:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It is a Roberts
However it may have been sold by others including boat builders such as Mullins.
Hope this helps
AJ
Posted on Sunday, February 22, 2009 - 07:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Ernie and Many Thanks!
You have just done what hours of searching did not.
Regards
Art
AJ
Posted on Monday, February 23, 2009 - 03:00 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Ernie
This post should now likely be moved to a different topic, however
I thought I would pass along the results of a little further research,
in the hope that some of it might prove of use, and help repay you
and the forum for your help. I have included the following patents
filed by Edmund Willson Roberts related to these engines.
These links to the patents use the Google search, which is indeed
a great concept but falls somewhat short in its implementation.
I use http://www.pat2pdf.org/ to download error free pdf copies.
Compressor (Combined Motor and Compressor)
Pat. # 883347 - http://tinyurl.com/cr2ve6
Back Fire Preventer (Cellular Bypass)
Pat. # 1101332 - http://tinyurl.com/bymxtt
Construction of Cylinders of Internal Combustion Engines
Pat. # 1210537 - http://tinyurl.com/bnx9ls
Another view of my friend’s engine
Engine Pic - 3
The following link to an earlier post with a very good match.
The basic engine, and perhaps the timer appear the same,
with the carb being different.
http://www.oldmarineengine.com/discus/messages/3454/103811.html
Once again Thank You and Congratulations to the forum – an amazing resource!
Regards
Art
