Leighton Engine
Old Marine Engine » Multi Cylinder Gas Inboards » Leighton Engine « Previous Next »
searcher
Username: searcher
Post Number: 285
Posted on Wednesday, February 18, 2009 - 12:46 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
That's a whole lot of Scheblers to keep in adjustment.
steve_fox
Username: steve_fox
Posted on Saturday, February 21, 2009 - 09:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Forget the carburetors. How would you like to start the crazy thing? This is a big engine even for 1906-7 (era of Chip III). Those cylinder look like they are for a 5" diameter piston. Everything would have to be set up perfectly and you would have had use a crowbar sized starting bar. God forbid the timing is a little off.
Post Number: 223
Posted on Sunday, February 22, 2009 - 08:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Did you have to start all cylinders at once?
