Marine plugs VS conventionial plugs
Old Marine Engine » Miscellaneous » Marine plugs VS conventionial plugs « Previous Next »
Norm McIntosh
Posted on Thursday, January 29, 2009 - 08:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I would like your opnions on marine plugs (surface gap) compared to conventional spark plugs for usage in older outboard motors.
Thanks for any input you can give
Norm
Post Number: 929
Posted on Friday, January 30, 2009 - 08:03 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Norm,
Surface gap plugs won't work well if at all without the necessary high output ignition they were designed to work with.
Hope this helps
