palmer engine cooling system |
Al Giles
| Posted on Wednesday, November 07, 2001 - 05:12 pm: |
I would like some info on a palmer marine engine 264 cubic inch. I need a flow diagram so I can tell which way the water travels thru the engine as it over heats there appears to be no thermostat it is rigged for fresh water cooling with a heat exchanger. There is one hose coming off the expansion tank that is plugged off and goes no where. I would like to know why. Thanks for any help Al Giles |
Richard Day
| Posted on Wednesday, November 07, 2001 - 11:29 pm: |
Sounds to me like a stuck thermostat. Will have to look up the service manual and get back to you Al. some expansion tanks have more than one outlet so is it on the sea water side or the fresh water side and what mix of anti freeze with water are us useing?. |
