Gray 6-51
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray 6-51 « Previous Next »
howard wisch jr
Username: hwischjr
Posted on Saturday, November 22, 2008 - 04:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Is the gray 6-51 not as tall as the 6-71, 6-75, chrysler crown? I have a 1940 Richardson Little Giant. I want to put in more power but my height is restricted. Appreciate any help in finding an engine that has the same height as the 6-51 but more power. Howard
mark johns
Username: mark_johns
Posted on Tuesday, November 25, 2008 - 06:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Howard, I also have a Little Giant which was powered by the 6:51 (which was siezed up} so ive managed to get a 6:71 which isnt fitted yet. As far as i know the size of these engines are the same, i have not noticed any difference.
howard wisch jr
Username: hwischjr
Posted on Tuesday, November 25, 2008 - 07:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
John, Does the 6-71 have one carb. or two? Many thanks- Howard
howard wisch jr
Username: hwischjr
Posted on Tuesday, November 25, 2008 - 07:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sorry, I meant Mark! How did that old girl end up on your side?
Howard
mark johns
Posted on Tuesday, December 02, 2008 - 10:54 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
As far as i know she was built for the uk as the controls are on the port side.The styling is for around 1936-40 but a nameplate says 1953.
This is when i think maybe she was shipped over as it was around this time petrol(gas) rationing was ended.(WW2)
As for the 6-71 Howard, im not sure if it actually is as the plate on the gearbox says 6-51.
In an earlier post i gave the engine numbers & this is what i was told, the engines look the same though.(Single carb setup).
Any info you have on this would be helpful Howard....Thanks ,Mark
mark johns
Post Number: 7
Posted on Tuesday, December 02, 2008 - 11:15 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Howard, ive just re read previos posts & i must of misread something as the engine i have is a 6-51 but 71 hp express,the old engine was a lugger @55hp.
Sorry mate,cant help with the 6-71 but maybe someone on here can.
By the way ,just out of interest what year is your Little Giant built?
...Many thanks, Mark
