Scott Noseworthy
Post Number: 56 Registered: 02-2008
| Posted on Wednesday, November 12, 2008 - 07:47 am: |
Hi guts a fella from taxes sent me these pictures of this engine wont's to know wot it is all help appeased timer has bin modified with points
Post Number: 1886 Registered: 11-2001
| Posted on Wednesday, November 12, 2008 - 11:41 am: |
* Gray Model "R". Water pumps moved to rear of engines in 1916. should be lots of info here through the search option ! Serial numbers can sometimes be found stamped into the raised boss just above the intake, or into the outer rim of the flywheel- these can be hard to find. With good numbers I can date the engine ! Scott Does the Mystic have any St Lawrence engines ? looking for info-- Serial numbers etc. * |
Post Number: 896 Registered: 01-2002
| Posted on Wednesday, November 12, 2008 - 12:06 pm: |
HUH!!!! Lockwood, Motorgo or Nadler not Gray S/N on forward end of crankshaft Guessing 1.5 hp or 2 hp |
Post Number: 1887 Registered: 11-2001
| Posted on Wednesday, November 12, 2008 - 04:26 pm: |
* Hey Ernie you are very right on the ID-- And that's not the only mistake I've made on here or even just today but I'm not mentioning the others ! * |
Scott Noseworthy
Post Number: 57 Registered: 02-2008
| Posted on Wednesday, November 12, 2008 - 04:39 pm: |
Ernie I was looking for a pictur of a nadler with the bump at the exaust thanks Richard no we dont have any St Lawrence engines sorry thanks guys |
Post Number: 408 Registered: 07-2002
| Posted on Wednesday, November 12, 2008 - 04:59 pm: |
2 1/2hp L-A or Motorgo, probably late teens. Early had the bolt on exhaust, latest had a two piece water pump strap. |
jamie hurry
Member Username: primetrucks
Post Number: 7 Registered: 03-2004
| Posted on Wednesday, November 12, 2008 - 05:54 pm: |
good job guys |
Hamp Phillips
New member Username: hamp_phillips
Post Number: 2 Registered: 04-2007
| Posted on Wednesday, November 12, 2008 - 06:31 pm: |
I have a restored St. Lawrence that I could let go if the price was right. The picture in the post Number:2 is not it. LEt me know if you are interested and I will post some pictures. Hamp |
Post Number: 1888 Registered: 11-2001
| Posted on Wednesday, November 12, 2008 - 07:28 pm: |
* Hamp Could you post some photos and list the serial number on the tag to help with our St Lawrence discussion Here ! Would also be a good way to advertise it ! * |
Hamp Phillips
Post Number: 3 Registered: 04-2007
| Posted on Wednesday, November 12, 2008 - 09:15 pm: |
The Tag says "The St Lawrence Engine Co.Limited" No 6885 Brockville, Ont. Canada I will post pictures later, Hamp |
