Might be marine, might be garden trac...
Old Marine Engine » Unknown Engines - post here with photos » Might be marine, might be garden tractor. « Previous Next »
William Schaller
Post Number: 170
Posted on Tuesday, October 14, 2008 - 05:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Might be marine, might be garden tractor. A friend had it at a local show in Minnesota. Anyone seen one like it? The carb has johnson on it, and it has been jury rigged a lot, but it could be based on a marine engine at one time.
Post Number: 882
Posted on Wednesday, October 15, 2008 - 12:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I had one, pretty sure it is a Maltby (Big Yellow Book) shows the air cooled flavor.
Also quite sure the water pump is a later add on.
Seems to me it was a car engine
Carb is from an outboard
Mike C from Conn has it now. Mike you around?
Post Number: 396
Posted on Wednesday, October 15, 2008 - 07:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Check out Ebay,
150303873964
