micheleinzunza
| Posted on Friday, October 10, 2008 - 04:40 am: |
i was given a 1970 seabird with twin 4cylinder inboard engines they have fomoco on them,the # on 1 motor is 93351 ,on other motor93436,cam# isMC24137,crank#2737E,they are gas engines,i know nothing about boats or motors ,but we would love to rebuild these motors but,ford cant even tell me what motors they are or what year ,can anyone out there please help me,thank you |
larry_from_maryland
Post Number: 321 Registered: 07-2003
| Posted on Friday, October 10, 2008 - 07:27 pm: |
Somewhere i have a partial key to fomoco numbers. I will be shows for the next few days so i may not find it soon. |
micheleinzunza
| Posted on Friday, October 10, 2008 - 09:33 pm: |
that is great i will be waiting to hear from you ,thank you |
Post Number: 875 Registered: 01-2002
| Posted on Saturday, October 11, 2008 - 05:16 pm: |
They MAY be Mercruiser blocks with 429 Ford heads I don't remember when Mercruiser made them, but they were never a real good engines so be carefull how much time and money you put in them. If you can get a casting number off the head I may be able to assist you. Ford cylinder head casting number locations You want to look in the 385 series heads click here If you can post pics of them I can possibly assist. If they are apart just set the head on the block and then the valve cover on the head. Also are they gas or diesel? Hope this helps Ernie |
micheleinzunza
| Posted on Sunday, October 12, 2008 - 06:58 pm: |
this is the numbers i found on the head T1,37,and the block has this number on it 681F6015DA,also there is a N and T1 and D-A,i hope these numbers will help identifying these motors ,thanks everyone for all your help |
Post Number: 877 Registered: 01-2002
| Posted on Sunday, October 12, 2008 - 07:18 pm: |
They don't sound Ford. Can you get us a pic? |
micheleinzunza
| Posted on Monday, October 13, 2008 - 12:15 pm: |
i will try to get pics asap,i seen a pic of a kent 1600 ohv , it is identical to the motors on boat ,is that possible that they are car motors |
larry_from_maryland
Post Number: 322 Registered: 07-2003
| Posted on Monday, October 13, 2008 - 01:00 pm: |
I have not found my book yet. I agree with ernie the numbers posted don't look like ford. |
micheleinzunza
| Posted on Monday, October 13, 2008 - 05:02 pm: |
okay ,this is what i have so far its a ford kent 1600 ,where the propellors are it has OMC ,then beneath that it says type c oil,the reason i believe they are these motors i seen a picture of a kent 1600 and they are identical,im greatful for all of the help,what i would like to know is how do i go about getting parts,do i look for omc parts or do i look for kent 1600 parts since its the head gaskets and o rings that i need,they are gas,and the boat is 23 ft long i dont know if that make a difference |
dave_myers
Post Number: 51 Registered: 11-2006
| Posted on Monday, October 13, 2008 - 05:43 pm: |
They are the same as the 1600 Ford Escort and Cortina and Capri. I do not know the actual model names for the USA. Any FOMOCO Dealer should have the parts required. OMC too costly. Dave |
micheleinzunza
| Posted on Monday, October 13, 2008 - 07:23 pm: |
thank you very very much i was checking out prices on omc parts and they are very expensive,i will go to ford dealer in the morning to see what i can get ,again thanks everyone for all of your help |
Moderator Username: andrew
Post Number: 950 Registered: 11-2001
| Posted on Monday, October 13, 2008 - 07:43 pm: |
michel, I'm not sure what parts you need, but don't use any automotive parts that are electrical such as a stater or distributor. Marine parts are more spark resistant because a boat is much more prone to explosion from gasoline vapor than a car is... There are lots of postings about the difference between automotive and marine parts on the marineengine.com board. |
