Sabb g info needed
Old Marine Engine » Diesel Inboards » Sabb g info needed « Previous Next »
rich_sv_jasmine
Username: rich_sv_jasmine
Posted on Monday, February 18, 2008 - 08:04 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just recently purchased a sabb g for a boat project. I would like to know what I should look for when it arrives. I would like to make it look good and probably paint her and replace some gaskets and in general make her a bit reliable. I am told the starter is non functional and I don't see the hand crank in the photos, so I would need to find or make one. It has the chain contraption that moves it to the front of the engine.
can anyone give me ideas as to what to look for in these engines? Can the starters be rebuilt easily? I would love to find sources for info on the care an maintenance of this engine.
I have found alot of (what I presume is) norwegian manuals online. Are there english ones somewhere?
Looking forward to having fun with this engine.
Thanks in advance for any advice.
rich
jimdereynier
Username: jimdereynier
Posted on Monday, February 18, 2008 - 05:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
(Rich,
I have a Sabb 2 H. Once you get the engine torn down and verify that all the crank parts are there, I have a crank you can have.
You should be able to get the English manual from the dealer
Bill Miller , sabbamerica@aol.com, (352) 589-2882- Phone works best.
The starter can be overhauled by automotive shop that does that work- You may need a shut off switch to cut the main power to the starter- My local guy must have messed up the solenoid windings. If the motor starts, the bendix will drop out otherwise I have to shut the main power off.
Good Luck.
Windy Miller
Posted on Wednesday, October 01, 2008 - 12:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Rich,
I have an english manual for your engine. Contact me if you want me to email a copy. Regards, Windy. windythemiller@yahoo.co.uk PS I need a cylinder head for mine if you know of any?
