Info./Pic's,etc. on 1947Scott-Atwater...
Old Marine Engine » Miscellaneous » Info./Pic's,etc. on 1947Scott-Atwater firestone outboard. « Previous Next »
47safirestone
Username: 47safirestone
Posted on Sunday, November 11, 2007 - 08:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hello,
i recentyly bought my FIRST vintage outbord,i beleive its a 47 firestone but need pics of one to verify.it is a 3.6hp.i have no pics of mine at this time but it looks almost identical to a 48 i saw,but this one had a cover covering the powerplant but exposed a choke button(which mine has)my powerplant is exposed...is mine missing?,i have many more ???.I AM ADDICTED NOW!!!,i'm in erie,pa.(LAKE ERIE IS MY "BACKYARD)thanks for ANY INFO,SUGGESTIONS,COMMENTS,ECT.
Post Number: 760
Posted on Monday, November 12, 2007 - 04:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here are pics of one with lower covers incorrectly decaled as a Johnson
click here
Here is one without lower covers
click here
I am fairly sure that they were available without lower covers with a lower unit like the one with covers as well.
Hope this helps
47safirestone
Posted on Monday, November 12, 2007 - 05:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank's ernie...i I.D.ed. my engine,a 1947 scott atwater firestone,the # was on a mount(& head)that a member had be check,#407-1881.i'm VERY happy,thanks again,darrin.
strapper
Username: strapper
Posted on Wednesday, September 10, 2008 - 03:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 1953 (3835) Scott-Atwater 10hp outboard.
I can not locate an operators manual. Question: On the front of this motor is a carb knob ranging from #1 to #12, what should this knob be set at to start the motor. Also the control arm band is missing. I believe the flat part of the handle should be up (starting position). I turned the jet all the way in and then out 1-1/4 turn. It will fire with starting fulid (not good for 2 cyl) so I know the electrical system is working. Any help anyone can give would be appreciated. Does anyone know where or who has an ops manual?
