Overheating problem
Old Marine Engine » Palmer Engine Co » Overheating problem « Previous Next »
Thomas Joyce
Username: tomjoyce
Posted on Wednesday, September 24, 2008 - 07:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 68/69 Palmer 6cyl, 150hp that is overheating. Checked both inboard and raw water pumps, replaced hoses, cleaned heat exchanger, overheats with or without thermostadt which appears to be working properly. A compression test when cold held pressure. A cooling system test when warm lost pressure immediately. The oil has remained clear. Any thoughts or suggestions would be most appreciated. Tom
