Found a serial no. breaker for perkins.
Old Marine Engine » Diesel Inboards » Found a serial no. breaker for perkins. « Previous Next »
larry_from_maryland
Username: larry_from_maryland
Post Number: 217
Posted on Friday, January 12, 2007 - 06:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I found a key for perkins serial numbers, now i can find the year made, county made in and id an engine from serial numbers.The key starts in 1974 and goes up,but many of the things apply to older numbers too.
claymore
Username: claymore
Posted on Monday, June 23, 2008 - 04:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Larry, I have a boat that has a marinised Perkins 6.354 in it, I am having problems finding out the Engine and Serial No. I checked the Perkins website and found the location for the number below the fuel pump and sure enough there was a number there, it looked like this:
CL C 0
805164 0
4
I contacted the local Perkins/Sabre Dealer and they said the number didn't make any sense to them. I know from their website what the number is supposed to look like but I can't find anything that looks similar on the engine. Any ideas? suggestions?
Jim
