Frisco Standard Gas Engine
Old Marine Engine » Multi Cylinder Gas Inboards » Frisco Standard Gas Engine « Previous Next »
Post Number: 1578
Posted on Saturday, November 17, 2007 - 05:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Frisco Standard Gas Engine ad 1922
FS1
FS2
FS3
doug charles
Posted on Tuesday, July 01, 2008 - 10:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This engine was air-starting, hence the extra set of downward-projecting rockers for the starting valves. The first 175 hp four was installed in Fidalgo Island Packing Co.'s tender Cydonia in 1915, running until replaced with a 160 hp Washington diesel in 1937. It was operated initially on distillate, but later the Campbell attachments for burning stove oil were installed. A massive backfire generally resulted from air starting. Unwary bystanders on the float alongside Cydonia were thoroughly soot-blasted. If conditions were perfect, the engine could be started by flicking an igniter, I've heard.
