Marine Engine Starter 1918
Old Marine Engine » Miscellaneous » Marine Engine Starter 1918 « Previous Next »
Post Number: 1716
Posted on Saturday, June 14, 2008 - 11:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
S18
Post Number: 371
Posted on Sunday, June 15, 2008 - 06:30 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It looks to be a compressor and an air distributor, seems like it would have had to been timed to the crankshaft, also would have to have a reservoir. Once started it would build air for the next start. On one of our trips we were thinking of a starter for Dickie Gibbens 3 cylinder Ferro, one thought was three air valves spaced 120 degrees apart around the crank with a sliding cam that could be brought under them. A line to each cylinder with a check valve would supply air on the down stroke.
