Carb on palmer 60
Old Marine Engine » Palmer Engine Co » Carb on palmer 60 « Previous Next »
Tom Kelly
Username: tom_k
Posted on Monday, June 02, 2008 - 12:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Made a mistake,dont fix it if it isn't broke,n.Tryed to add a PVC kit to my palmer 60.The kit is offered by Indigo for atomic 4,s.Started with lots of vacume problems and ended not running at all?Cant figure it out at this point.
Post Number: 608
Posted on Monday, June 02, 2008 - 04:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What was wrong with the normal P-60 PCV system could not be simpler or trouble free???
Tom Kelly
Username: tom_k
Posted on Monday, June 02, 2008 - 05:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The tube was removed by the previous owner,when I discovered the system I decided to put it back the way it was.But now I have a new set of problems.It engine acts like its out of gas but the fuel bowl is full.
Post Number: 609
Posted on Monday, June 02, 2008 - 08:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Do you mean he removed the el faceing toward the reverse gear on the valve cover plate behind the carburetor. If that is the case I can send you a replacment valve cover plate. all you need is a short length of plastic pipe to connect the valve cover tube to the tube on the back fire trap. Air flow over the PCV tube on the face of the backfire trap reduces the air pressure in the crankcase and the filter in the dip stick allows air to flow into the crankcase. It should be cleaned with gasoline occasionly as it picks up lint and what little dust one has on most boats.
The valve cover plate has an inside plate which keeps the oil in the crankcase from being sucked into the carburetor intake. Sound like you must have a blockage in the needle valve portion of the carburetor.
