Sprocket missing every other tooth |
john rendemonti
Member Username: rendo
Post Number: 13 Registered: 08-2006
| Posted on Wednesday, April 02, 2008 - 11:33 pm: |
My hand crank sprocket is missing every other tooth. appears to be a 1/2 pitch if the tooth was there. Where do I find chain for a sprocket missing every other tooth? Thanks. John 484-459-0880 |
George P Dorris
New member Username: rusthunter
Post Number: 1 Registered: 10-2004
| Posted on Thursday, April 03, 2008 - 01:34 pm: |
This type of chain is called block chain. The last time I bought some was from Boston Gear. I called them this morning but they seemed clueless. The chain that I have is 1" pitch 1/4" wide. As I remember that was all I could buy. Have not located a source for sprockets yet, if I get time I will try again. |
john rendemonti
Post Number: 14 Registered: 08-2006
| Posted on Thursday, April 03, 2008 - 10:38 pm: |
I found an engineer at Diamond and he advised me that it is called "laminated block chain". I googled it and found a source, horribly expensive, but still available. My sprocket is .350, much wider than bicycles of the early days. John |
Rob Rowe
| Posted on Friday, April 18, 2008 - 07:52 am: |
I noticed some Meadows marine engines on EBay are these of interest to anyone,there was 3 days to go. |
Andrew Selman
Member Username: andys
Post Number: 6 Registered: 05-2007
| Posted on Friday, April 18, 2008 - 08:18 am: |
Rob Do you have the ebay references? I did not see them. Andy |
