Dan Boyle
New member Username: boyle1770
Post Number: 1 Registered: 04-2006
| Posted on Monday, April 17, 2006 - 04:20 pm: |
DO YOU KNOW WHAT YEAR JOHNSON MADE THIS 33HP MOTOR? ANY OTHER INFO. WOULD BE OF GREAT HELP TO ME. ANY SITES FOR PARTS LISTS, ETC. THANKS TO ALL THAT REPLY
foxman Visitor
| Posted on Thursday, April 20, 2006 - 09:20 pm: |
I would say 1960-1965 (ish). I don't think the frost plug # is the model #, that's just a part #. The model # should be on an small aluminum id plate located on the transom clamp mount right under the control bracket shown in the lower photo. This was a very common and very popular boat engine in the 60's and there should be hundred's of parts motors around. Check an older back country marina with a motor graveyard in the back. If it's a matter of part or die, you might be able to check Terry Kilcoyne at american outboard parts-check web for name or you can check the old outboard club at aomci.org. 60's outboards are in vogue now and parts and info should be available. |
Dan Boyle
Post Number: 2 Registered: 04-2006
| Posted on Thursday, April 20, 2006 - 09:27 pm: |
Thanks a million for the info. I will check there tomorrow to see if I can find the model number id tag. Thanks again for your knowledge....much appreciated!! |
