Hallett Diesel Engine
Old Marine Engine » Diesel Inboards » Hallett Diesel Engine « Previous Next »
caddyshack1982
Username: caddyshack1982
Posted on Monday, September 11, 2006 - 06:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone have any information on a Hallett Diesel Engine Model #AC-1S, Serial #AC10082. I'm having now luck finding any information on the engine or the company that produced it?
Any help would be much appreciated.
Post Number: 1211
Posted on Monday, September 11, 2006 - 06:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Not a lot of info on this Co.virtually no ads in marine pubications as yet.
Hallet Mfg Company
Hyde Park Station, Los Angeles, California
Diesel Progress Mag stated their first Diesels were mfgd in 1916.
A senior member here has a Hallet Gas Marine engine !
This is from Wendels Book.
H
caddyshack1982
Posted on Monday, September 11, 2006 - 11:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard, thanks for the info. Every little bit helps on this one.
Brett
enginenut
Username: enginenut
Post Number: 8
Posted on Friday, October 06, 2006 - 12:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a little bit I can add on Hallett from "Diesel Engine Catalog"--nothing earlier than 1945 which listed only a model D1A, water cooled, 8 Hp @ 1500 R/M.
By 1954 a D2 had been added which was 2 cyl, 20 Hp,566 lbs, and both it and the D1, now rated 10HP ran @ 1800 R/M.
Also the model C had been added;
AC1;(air cooled)1 cyl,6 HP,220 lbs
AC2; 2 cyl,13 HP,350 lbs
WC1(water cooled);1 cyl,7 HP, 250 lbs
WC2; 2 cyl,14 HP, 375 lbs
WC4; 4 cyl,30 HP, 480 lbs
the Model D was 3 7/8 x 4 1/4 and the model C 3 1/2 x 3 3/4 B&S.
the suffex "s" designated stationary while a "m" meant marine.They state "all models can be furnished with reduction and reverse gears".
enginenut
Username: enginenut
Post Number: 9
Posted on Friday, October 06, 2006 - 12:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jumping ahead to 1959, we find the model D has disappeared also the WC4, the rest of the offerings remain the same but a lot of emphasis on a line of direct mounted generators of 3 and 5 KW for the AC engines.
But now we find them under a new name of American MARC, Inc.(notice the capitalization of MARC but not American)at the same address and a statement;"American MARC incorporated in September, 1955, has grown to a dominant position in the manufacture of lightweight, air-cooled Diesel engines over a relatively short span of time.Using the advanced designs of European engineers as a criteria.
By 1968, I don't find American MARC listed anymore but let me mention one of their engines I lust for.This is a diesel outboard of 2 stroke, crancase compression, OPPOSED PISTON(not opposed cylinder)design.Meaning each cylinder would use 2 pistons, 2 connecting rods, and 2 crankshafts throws.
If you go to "The Antique Outboarder Archive" and find in the archive; American MARC also AMARC you will see 2 advertisements for this engine in 7.5, 15, and 22 HP while 1 ad seems to be offering it at nominal 10(9 1/4 actual)HP.Probably 7.5 HP cyl packages were added for the higher HP engines but this is not stated.
These ads are dated(?)as 1972 and show a schematic and exploded view of a single cyl package.
I'd like to hear testamony concerning these odd engines-surely someone out there owned or maintained them.I have also seen this engine re-badged and offered by McCulloch.
Hope this helps.
goldfinch7
Posted on Tuesday, October 10, 2006 - 02:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
enginenut, you just made my day! i've been searching for info of any kind on this engine, and have been coming up with nothing. i'm posting a picture of it here...
alfred_da_rosa
Username: alfred_da_rosa
Posted on Tuesday, September 28, 2010 - 10:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank you very much Lawrence T. Wolfe (Larry), for your information about the Buda 230.
Now I have an old tractor that might interest you. I can send more information, make, year, and photography tractor.
If you are interested please write
alfred_da_rosa
Posted on Tuesday, September 28, 2010 - 10:36 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bernard Dodd
Posted on Monday, November 25, 2013 - 09:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Associated Manufacturers Company [London] UK were advertising Hallett marine engines in their 1928 catalogue.
robert
Username: robert
Post Number: 632
Posted on Monday, November 25, 2013 - 11:03 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
There's a twin Hallet upright in a scrap yard near here, looks relatively complete if anyone wants to save it.
Richard Ballantyne
Posted on Wednesday, April 23, 2014 - 08:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Hallett diesel generator. I also have the service manual which I scanned in at 600dpi. The URL to the manual is here:
https://drive.google.com/file/d/0B23L1iUAnu2zVDdzV3pKYm9Wc1E/edit?usp=sharing
Enjoy!
