Kermath Model 150
Old Marine Engine » Multi Cylinder Gas Inboards » Kermath Model 150 « Previous Next »
midpw
Username: midpw
Posted on Wednesday, May 21, 2008 - 03:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi there........
A friend has a 1929 Kermath 6 cyl 12 plug engine that was removed from his chris craft runabout. He has asked me to nose around a bit and eventually get it into my garage and see about getting it to run. It appears to be in pretty good shape and won't require tear down much beyond maybe the head to check the valve train. My quest is to gain as much information as possible so that once I get it into my shop I can be somewhat comfortable. Any Kermath guru's out there??? Thank you in advance for any advice.
Bruce Zimmerman
Saint Ignace Michigan
andys
Username: andys
Post Number: 7
Posted on Thursday, May 22, 2008 - 04:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Do you have any pictures and has your friend replaced this engine in his boat or does he intend to put it back in?
Thanks Andy
